New Data from AO
The four disks from AO have arrived - about 5TB of data. I have queued them up for pre-processing (radar blanking) so new SETI@Home workunits should be going out soon. 5 Dec 2014, 17:54:33 UTC · Kommentar
Dear Primefinder,
Congratulations! Our records indicate that a computer registered by you has found a unique prime number. This computer is running BOINC, is attached to the PrimeGrid project, and is assigned to the Sophie Germain Prime Search. What makes this prime unique is that it's large enough to enter the Top 5000 List in Chris Caldwell's The Largest Known Primes Database.
Since you have auto-reporting selected, the following prime was submitted on your behalf:
Added 119156 : 1780769236977*2^1290000-1 (388341 digits)
This prime was found on this workunit which will automatically show as a prime result after verification by the Largest Known Primes Database.
If you have any questions or concerns, please contact us and we will surely resolve any problems.
Once again, congratulations on your find! Thank you for participating in PrimeGrid.
PrimeGrid staff
Glückwunsch!
...Added 119228 : 3989*2^1316593+1 (396338 digits)
Welches Projekt soll denn sein?
Wenn ich die Fasnet überstanden hab mach ich was rein.![]()
Dann gibts Seti in der KW 10
Scheiß Rechner Abwärme
Bei derzeitigen 26,8° C inner Bude drehen meine Indoor Bonsais schon durch![]()
