/v/log ❯❯❯ sudo tail -n 1000 daemon.log | grep Network
Mar 16 19:14:57 crunch-573g systemd[1]: Stopping Network Time Service...
Mar 16 19:15:51 crunch-573g avahi-daemon[382]: Network interface enumeration completed.
Mar 16 19:15:56 crunch-573g systemd[1]: Started Network Manager.
Mar 16 19:15:56 crunch-573g systemd[1]: Starting Network.
Mar 16 19:15:56 crunch-573g systemd[1]: Reached target Network.
Mar 16 19:15:56 crunch-573g systemd[1]: Starting Network Time Service...
Mar 16 19:15:56 crunch-573g systemd[1]: Started Network Time Service.
Mar 16 19:16:10 crunch-573g systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 16 19:16:10 crunch-573g systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 16 20:53:23 crunch-573g systemd[1]: Started Network Manager.
Mar 16 20:53:23 crunch-573g systemd[1]: Starting Network.
Mar 16 20:53:23 crunch-573g systemd[1]: Reached target Network.
Mar 16 20:53:23 crunch-573g systemd[1]: Starting Network Time Service...
Mar 16 20:53:24 crunch-573g systemd[1]: Started Network Time Service.
Mar 16 20:53:35 crunch-573g systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 16 20:53:35 crunch-573g systemd[1]: Started Network Manager Script Dispatcher Service.
/v/log ❯❯❯ sudo tail -n 1000 errors.log | grep Network
Mar 6 11:46:56 crunch-573g NetworkManager[388]: stop: assertion 'priv->pid > 0' failed
Mar 6 11:48:21 crunch-573g NetworkManager[388]: stop: assertion 'priv->pid > 0' failed
Mar 6 12:07:16 crunch-573g NetworkManager[388]: stop: assertion 'priv->pid > 0' failed
Mar 6 12:27:37 crunch-573g NetworkManager[388]: stop: assertion 'priv->pid > 0' failed
/v/log ❯❯❯ sudo tail -n 1000 messages.log | grep Network
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> (wlp4s0): supplicant interface state: associating -> 4-way handshake
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> (wlp4s0): supplicant interface state: 4-way handshake -> completed
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'xxx'.
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 3 of 5 (IP Configure Start) scheduled.
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 3 of 5 (IP Configure Start) started...
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> (wlp4s0): device state change: config -> ip-config (reason 'none') [50 70 0]
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Beginning DHCPv4 transaction (timeout in 45 seconds)
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> dhcpcd started with pid 1411
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Beginning IP6 addrconf.
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 3 of 5 (IP Configure Start) complete.
Mar 16 20:53:28 crunch-573g NetworkManager[412]: <info> (wlp4s0): DHCPv4 state changed nbi -> preinit
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> (wlp4s0): DHCPv4 state changed preinit -> bound
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> address 192.168.1.103
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> prefix 24 (255.255.255.0)
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> gateway 192.168.1.1
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> nameserver '192.168.1.1'
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> domain name 'private.lan'
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Mar 16 20:53:34 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 5 of 5 (IPv4 Commit) started...
Mar 16 20:53:35 crunch-573g NetworkManager[412]: <info> (wlp4s0): device state change: ip-config -> secondaries (reason 'none') [70 90 0]
Mar 16 20:53:35 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 5 of 5 (IPv4 Commit) complete.
Mar 16 20:53:35 crunch-573g NetworkManager[412]: <info> (wlp4s0): device state change: secondaries -> activated (reason 'none') [90 100 0]
Mar 16 20:53:35 crunch-573g NetworkManager[412]: <info> NetworkManager state is now CONNECTED_GLOBAL
Mar 16 20:53:35 crunch-573g NetworkManager[412]: <info> Policy set 'xxx@xxx' (wlp4s0) as default for IPv4 routing and DNS.
Mar 16 20:53:35 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) successful, device activated.
Mar 16 20:53:49 crunch-573g NetworkManager[412]: <info> (wlp4s0): IP6 addrconf timed out or failed.
Mar 16 20:53:49 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Mar 16 20:53:49 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Mar 16 20:53:49 crunch-573g NetworkManager[412]: <info> Activation (wlp4s0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Mar 16 20:53:58 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 20:57:07 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 20:58:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:08:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:10:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:14:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:16:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:18:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:36:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:40:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:42:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:44:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:46:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:48:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:50:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:54:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 21:58:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:00:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:02:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:06:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:08:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:12:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:14:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:18:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:24:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:28:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:32:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:38:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:40:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:44:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 22:58:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:04:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:08:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:10:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:12:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:14:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:18:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:20:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:24:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:28:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:30:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:36:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:40:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:46:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:50:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:54:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:56:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 16 23:58:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 17 00:00:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 17 00:02:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 17 00:04:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 17 00:06:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 17 00:10:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
Mar 17 00:18:50 crunch-573g NetworkManager[412]: <warn> nl_recvmsgs() error: (-33) Dump inconsistency detected, interrupted
