[VIDEO] Heute bist Du noch nicht dran...
MSX
Retro-Nerd-Hippie
v01d
  • #744
https://i.imgur.com/wYWQYi7.gifv
Also, aufgestanden ist er zumindest wieder. :-D
Wenn einem sonst schon nichts Gescheites im Schädel rumgeht, dann nun vielleicht eine Mikrowellentür...
Ein Mensch hat dazu ein paar Berechnungen gepostet, die ich euch nicht vorenthalten will:
If you download the video, the frame rate was 30fps and it took the piece of metal 12 frames to reach the cameraman (or camerawoman) so that was so that was a total time of 0.4s to travel a distance equivalent to ~25 steps (the amount of steps that the woman ran after lighting it up). Assuming that each step was ~1m, that would be equal to roughly 25m.
Avg. Velocity = Δdistance/Δtime = 25m/0.4s = 62.5m/s
Assuming that the piece was made of a stainless steel alloy (like this microwave part) with a density of 7,750kg/m3 with dimensions of 0.4mm (0.0004m) x ~0.5m x ~0.25m; the mass of the piece was the following:
Mass = (volume)(density) = (0.0004m)(0.20m)(0.4m)(7,750kg/m3)=0.248kg
The Avg. momentum that the piece had was then: p=massAvg. velocity=(0.248kg)(62.5m/s)=15.5kg*m/s
If we assume that the object stopped completely, the change in momentum would equal the Avg. momentum minus zero (final momentum). Newton's 2nd Law (F=m*a) is really just the change in momentum with respect to time (what appears to be ~2 frames in the video), so we get that the force exerted on the person by the object was:
F=Δp/Δt=(15.5kgm/s)/(2frames/30fps)=232.5N (roughly 52 pounds of force*)
Depending on the angle at which it impacted the person, it could have caused significant damage (if it impacted on the sharper edge, with less surface area to decrease the force/area (stress) that the body part would have been subjected to. In the video it seems as if he got lucky and was hit with the larger area side.
Ein anderer User verlinkte dann noch diese wahre Fundgrupe noch überlebender Menschen: https://www.reddit.com/r/watchpeoplesurvive/
MSX
Retro-Nerd-Hippie
v01d
  • #746
Da hab ich das fast schon übliche Reinfahren eines Autos erwartet, aber wurde doch überrascht. :-D
Scheint jemand nicht so ganz mit den PS seines Wagens umgehen zu können. :-)
Wobei im 1. Fall ich nicht von Leichtsinn ausgehe, sondern einer maroden Feuerleiter. Ich nehme an, die wollten Eis und/oder Schnee vom Dach räumen.
Ich weiß nicht, mag auch sein, dass ich da einen völlig falschen Eindruck habe, aber die Leiter sieht für mich schon auf den ersten Blick nicht sonderlich sicher aus. Da würde ich mir zweimal überlegen, ob ich die gleich mit 2 Personen nutzen würde oder lieber warte, bis die erste oben ist ;)
Noch so ein potentieller Kandidat für den Darwin-Award. War auf jeden Fall eine schmerzhafte Lektion:
MSX
Retro-Nerd-Hippie
v01d
  • #752
Was könnte da schon schiefgehen! :-D
